04-27-2009 11:42 AM - edited 03-06-2019 05:24 AM
I am running the following:
isco IOS Software, C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5
and I am unable to define static routes?
I thought ip routing is enabled by default.
Any idea?
04-27-2009 11:44 AM
"I thought ip routing is enabled by default."
Not on the 2960 as this is a L2 switch only. Try
"ip default-gateway x.x.x.x"
Jon
04-27-2009 11:49 AM
hi Jon,
Is this not for management purposes only? Thus for management from another vlan.
As you say it's a layer 2 switch isn't it that you can only define 1 SVI for management. The switch itself can only be used as L2 access switch with ports in different vlans and uplink to a core/distribution layer device
04-27-2009 11:45 AM
I believe a 2960 is a layer2 switch which doesn't route. You'll need to create your static routes on your router.
HTH,
John
04-27-2009 11:46 AM
Roni,
Okay Cisco 2960 switch is a layer2 switch.
It's not true. You can't do that.
IP address assigned to the vlan interface of Layer2 switch will be used for management propose.
HTH,
Toshi
04-27-2009 11:49 AM
The 2960 switch isn't Layer 3 capable, meaning no static routes and no ip routing. You can only define a management IP with a default gateway.
hth
edit: sorry a couple of minutes late ;-)
04-27-2009 11:52 AM
Ingo,
That's fine. (grin)
Toshi
