Two calls at the same time
Chris Deren Mon, 04/27/2009 - 12:05
Are you saying that both calls are coming from ACD or is the second call a direct call?
Your ACD line in CM should be configured with busy trigger of 1 so that only one call can be delivered to this line at a time.
andrew.higgins Mon, 04/27/2009 - 15:27
There are a couple of bugs that may be related to your issue.
CSCsm42626 - Different conferences are joined together. This could occur if agents are performing warm transfers.
CSCsj99361 - IP Phone continues to generate RTP packets after call is disconnected.
