Upgrading PIX
Answered Question
Apr 27th, 2009
I have a PIX 515E that i have to upgrade
currently it's running 6.3(5)and i'm going to 8.0(4)28,what i wanted to know is do i have to upgrade to 7 before i can upgrade to 8.Or can i go directly to version 8
Correct Answer by JORGE RODRIGUEZ about 7 years 8 months ago
Version 8.0(3) requires the following:
Go over this link
http://www.cisco.com/en/US/docs/security/pix/pix80/release/notes/prn803.html
quote from link above
•The minimum software version required before upgrading to PIX Version 8.0(3) is PIX Version 7.2. If you are running a PIX version earlier than Version 6.2, you must first upgrade to PIX Version 6.2 or PIX Version 6.3 before you can upgrade to PIX Version 7.2.
Above applies to version 8.0.4 as well
http://www.cisco.com/en/US/docs/security/pix/pix80/release/notes/pixrn804.html
Overall Rating: 5 (1 ratings)
Correct Answer
JORGE RODRIGUEZ Mon, 04/27/2009 - 13:05
Go over this link
scooter817 Mon, 04/27/2009 - 13:15
You know i already had that link,i just seconded guess my self,thanks Jorge and have a great day
