Help with WLC 4402 and Ap 1242AG
Apr 27th, 2009
Hi I need some ideas this is the problem:
I have a small network in which I have 5 aps 1242 ( The Aps were autonomous and now there are lightweight) and a WLC 4402, and everything was working fine until the APs failed to record in controller, when I saw the loggs in the aps that indicate that the Ap can not see the controller, The controller works in Layer 2,the Aps and WLC are in the same segment,they are connect to the same switch. I put the Controller logs in the cisco output interpreter and this is what resulted:
ERROR MESSAGE NOTIFICATIONS (if any)
%SIM-3-ARP_SND_FAIL (x1): Unable to send ARP Request. Local MAC: [hex]:[hex]:[hex]:[hex]:[hex]:[hex].Ip
Addr: [int].[int].[int].[int]Interface # [dec]. Vlan Id: [dec]
Explanation: Unable to send ARP Request.
%DTL-3-ARP_SEND_FAILED (x1): Could not send [chars] to [hex]:[hex]:[hex]:[hex]:[hex]:[hex].
VLAN=[dec], Intf=[dec]. [chars].
Explanation: Could not send an ARP packet.
%SYSNET-3-INV_IF (x1): Circuit Error - vlan id & intIfNum = 0.
Explanation: Circuit Error - Both vlan id & intIfNum are 0.
%SIM-3-PORT_GETSTATE_FAIL (x1): Unable to get link state for port [dec] of interface[chars].
Explanation: Unable to get link state for a port
%LWAPP-3-DECODE_ERR (x4): Error decoding [chars] from AP [hex]:[hex]:[hex]:[hex]:[hex]:[hex]
Explanation: The LWAPP message sent by the AP was not understood by the controller,
the message was dropped. AP may not function as expected.
%LWAPP-3-DISC_OTAP_ERR (x4): Ignoring OTAP discovery request from AP [hex]:[hex]:[hex]:[hex]:[hex]:[hex],
OTAP is disabled
Recommended Action: Copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs.
If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://tools.cisco.com/ServiceRequestTool/create/launch.do,
or contact your Cisco technical support representative and provide the representative with the information you have gathered.
**Note this recommended action its by the previously messajes
Explanation: Controller received discovery request from an AP that learnt the
controller's address over the air, but Over The Air Provisioning (OTAP) is disabled
on the controller.
Recommended Action: Enable OTAP on the controller if desired, otherwise this
message can be ignored.
%LWAPP-3-DISC_AP_MGR_ERR1 (x4): Unable to process primary discovery request
from AP on interface ([int]), VLAN ([int]), could not get AP manager [hex]:[hex]:[hex]:[hex]:[hex]:[hex]
Explanation: A discovery response could not be sent to an AP because the controller
was not able to obtain the IP address of the AP manager interface
Recommended Action: Correct the AP manager interface configuration.
No information on error code CAPWAP-3-DISC_AP_MGR_ERR1
No information on error code CAPWAP-3-DECODE_ERR
No information on error code DTLS-3-HANDSHAKE_FAILURE
the version of the wlc is AIR-WLC4400-K9-5-2-178-0.aes, the trafic betten the wlc and the aps is by the native vlan
Scott Fella Mon, 04/27/2009 - 12:40
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
You need to set the WLC in Layer3 mode and make sure there is a dhcp on that subnet for the ap's to obtain an ip address. Your ap's should be able to find and join the wlc now. Layer 2 mode was for support of the 1000 series AP's.
xeum96700 Mon, 04/27/2009 - 12:44
I try to do this, but i continue with the problem, the aps have static ip and the ip of the controller
Scott Fella Mon, 04/27/2009 - 12:46
  • Hall of Fame,
    2017 Wireless
Set it in Layer 3 and then console into the ap and post the log. I need to see what is happening after the ap boots.
xeum96700 Mon, 04/27/2009 - 13:06
this is the log of the ap:
*Apr 22 10:38:41.166: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 10:38:50.076: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-LWAPP-CONTROLLER
*Apr 22 10:38:59.077: %CAPWAP-3-ERRORLOG: Could Not resolve CISCO-CAPWAP-CONTROLLERwtpDecodeDiscovery Response numOfCapwapDiscoveryResp = 0
wtpDecodeDiscovery Response numOfCapwapDiscoveryResp = 1
*Apr 22 10:39:09.078: capwapHandleDiscoveryTimer Expired
*Apr 22 10:39:09.078: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 22 10:39:09.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: x.x.x.x.x peer_port: 5246
*Apr 22 10:39:23.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:1924 Max retransmission count reached!
*Apr 22 10:39:23.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for x.x.x.x.x is reached.
*Apr 22 10:40:09.054: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Apr 22 10:40:09.065: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to administratively down
*Apr 22 10:40:09.065: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Apr 22 10:40:09.076: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 10:40:09.076: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to upwtpDecodeDiscovery Response numOfCapwapDiscoveryResp = 0
*Apr 22 10:40:09.078: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 10:40:09.108: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 10:40:09.109: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Apr 22 10:40:09.137: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Apr 22 10:40:09.138: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Apr 22 10:40:09.168: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Apr 22 10:40:19.076: capwapHandleDiscoveryTimer Expired
*Apr 22 10:40:19.076: %CAPWAP-3-ERRORLOG: Go join a capwap controller
*Apr 22 10:40:19.000: %CAPWAP-5-DTLSREQSEND: DTLS connection request sent peer_ip: x.x.x.x.x peer_port: 5246
*Apr 22 10:40:33.000: DTLS_CLIENT_ERROR: ../dtls/dtls_connection_db.c:1924 Max retransmission count reached!
*Apr 22 10:40:33.000: %DTLS-3-HANDSHAKE_RETRANSMIT: Max retransmit count for x.x.x.x.x is reached.
*Apr 22 10:41:19.054: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
Scott Fella Mon, 04/27/2009 - 13:49
  • Hall of Fame,
    2017 Wireless
This is a new install correct? Can you post your show run-config?
xeum96700 Mon, 04/27/2009 - 14:07
this is the configuration
Building configuration...
hostname DIRECCION
aaa new-model
aaa authentication login default local
aaa session-id common
eap profile lwapp_eap_profile
method fast
crypto pki trustpoint Cisco_IOS_MIC_cert
revocation-check none
rsakeypair Cisco_IOS_MIC_Keys
crypto pki trustpoint cisco-root-cert
crypto pki trustpoint airespace-device-root-cert
crypto pki trustpoint airespace-new-root-cert
crypto pki trustpoint airespace-old-root-cert
crypto pki certificate chain Cisco_IOS_MIC_cert
certificate 6CB1AAF100000005B9FA
30820468 30820350 A0030201 02020A6C B1AAF100 000005B9 FA300D06 092A8648
86F70D01 01050500 30393116 30140603 55040A13 0D436973 636F2053 79737465
certificate ca 6A6967B3000000000003
308204D9 308203C1 A0030201 02020A6A 6967B300 00000000 03300D06 092A8648
86F70D01 01050500 30353116 30140603 55040A13 0D436973 636F2053 79737465
6D73311B 30190603 55040313 12436973 636F2052 6F6F7420 43412032 30343830
crypto pki certificate chain cisco-root-cert
certificate ca 5FF87B282B54DC8D42A315B568C9ADFF
30820343 3082022B A0030201 0202105F F87B282B 54DC8D42 A315B568 C9ADFF30
0D06092A 864886F7 0D010105 05003035 31163014 06035504 0A130D43 6973636F
20537973 74656D73 311B3019 06035504 03131243 6973636F 20526F6F 74204341
crypto pki certificate chain airespace-device-root-cert
certificate ca 03
3082047F 308203A8 A0030201 02020103 300D0609 2A864886 F70D0101 04050030
81A6310B 30090603 55040613 02555331 13301106 03550408 130A4361 6C69666F
726E6961 3111300F 06035504 07130853 616E204A 6F736531 17301506 0355040A
crypto pki certificate chain airespace-new-root-cert
certificate ca 00
3082045A 30820383 A0030201 02020100 300D0609 2A864886 F70D0101 04050030
crypto pki certificate chain airespace-old-root-cert
certificate ca 00
30820406 3082032F A0030201 02020100 300D0609 2A864886 F70D0101 04050030
818F310B 30090603 55040613 02555331 13301106 03550408 130A4361 6C69666F
username cisco secret 5
ip ssh version 2
interface Dot11Radio0
no ip route-cache
mbssid
power client local
packet retries 64 drop-packet
interface Dot11Radio1
no ip route-cache
shutdown
mbssid
power client local
interface FastEthernet0
ip address 192.168.0.240 255.255.255.0
no ip route-cache
duplex auto
speed auto
ip default-gateway 192.168.0.254
logging trap errors
logging origin-id string AP:001d.a1fc.ad36
logging snmp-trap notifications
logging snmp-trap informational
logging snmp-trap debugging
logging 0.0.0.0
Scott Fella Mon, 04/27/2009 - 14:21
  • Hall of Fame,
    2017 Wireless
Sorry... Need you to run this on the wlc cli. Put it ito a text file and post it.
xeum96700 Tue, 04/28/2009 - 07:17
Show running-config
advanced 802.11b monitor Channel-list all
location rssi-half-life tags 0
location rssi-half-life client 0
location rssi-half-life rogue-aps 0
location expiry tags 5
location expiry client 5
location expiry calibrating-client 5
location expiry rogue-aps 5
Cisco Public Safety is not allowed to set in this domain
ap syslog host global 255.255.255.255
country MX
local-auth method fast server-key 73656372657
interface create datos 30
interface create voz 40
interface address ap-manager z.z.0.238 255.255.254.0 z.z.0.254
interface address dynamic-interface datos z.z.30.251 255.255.254.0 z.z.30.254
interface address management z.z.0.239 255.255.254.0 z.z.0.254
interface address service-port 2.2.2.2 255.255.255.252
interface address virtual 1.1.1.1
interface address dynamic-interface voz z.z.40.250 255.255.254.0 z.z.40.254
interface dhcp ap-manager primary z.z.0.254
interface dhcp dynamic-interface datos primary z.z.30.254
interface dhcp management primary z.z.0.254
interface dhcp service-port disable
interface dhcp dynamic-interface voz primary z.z.40.2
interface vlan datos 30
interface vlan voz 40
interface port ap-manager 29
interface port datos 29
interface port management 29
interface port voz 29
rogue ap friendly add 00:0d:54:a4:10:94
rogue ap friendly add 00:a0:f8:b2:6a:00
lag enable
load-balancing status enable
load-balancing window 5
apgroup add default-group
apgroup interface-mapping add default-group 1 datos
apgroup interface-mapping add default-group 2 voz
wlan apgroup nac disable default-group 1
wlan apgroup nac disable default-group 2
memory monitor error disable
memory monitor leak thresholds 10000 30000
mesh security rad-mac-filter disable
mesh security eap
mobility dscp 0
network webmode enable
network telnet enable
network master-base enable
network mgmt-via-wireless enable
network ap-priority disabled
network otap-mode disable
network rf-network-name
port autoneg 1 disable
port physicalmode 1 1000sx
radius fallback-test mode off
radius fallback-test username cisco-probe
radius fallback-test interval 300
rogue ap classify malicious state contain 00:10:e7:b5:a2:95 1
rogue ap classify malicious state contain 00:21:7c:35:5d:61 3
rogue ap ssid alarm
rogue ap valid-client alarm
rogue adhoc enable
rogue adhoc alert
rogue ap rldp disable
snmp version v2c enable
snmp version v3 enable
spanningtree port mode off 1
spanningtree port mode off 2
sysname
trapflags mesh excessive hop count disable
trapflags mesh sec backhaul change disable
wlan create 1 xxxx xxxx
wlan create 2 yyyy yyyy
wlan nac disable 1
wlan nac disable 2
wlan interface 1 datos
wlan interface 2 voz
wlan broadcast-ssid disable 2
wlan session-timeout 1 1800
wlan session-timeout 2 1800
wlan h-reap learn-ipaddr 1 enable
wlan h-reap learn-ipaddr 2 enable
wlan wmm allow 1
wlan wmm allow 2
wlan security wpa disable 1
wlan security wpa disable 2
wlan security static-wep-key enable 1
wlan security static-wep-key enable 2
wlan security static-wep-key authentication shared-key 1
wlan security static-wep-key authentication shared-key 2
wlan security static-wep-key encryption 1 104 1
wlan security static-wep-key encryption 2 104 1
wlan security wpa akm 802.1x disable 1
wlan security wpa akm 802.1x disable 2
wlan security wpa akm ft reassociation-time 20 1
wlan security wpa akm ft over-the-air enable 1
wlan security wpa akm ft over-the-ds enable 1
wlan security wpa akm ft reassociation-time 20 2
wlan enable 1
wlan enable 2
license agent default authenticate none
Robert.N.Barrett_2 Tue, 04/28/2009 - 16:06
  • Bronze, 100 points or more
Can you tell us what version of code you are running?
Can you connect to the console port of an AP and ping the controller IP? You mention above that the AP's have the address of the controller - what address? Management or AP Management? Usually, once the AP's have the Management ip address set, they immediately join the controller. If they can't reach the controller, or if the controller's time is not set, then they won't be able to join.
xeum96700 Wed, 04/29/2009 - 08:31
Its the show running part
Yes I can ping the ip of the wlc, the address is the management. the version of the wlc its the newest
I put a new wlc whit the newest version of software and the aps can't joint the wlc.
I made a Lab with the wlc and one Ap, I converting the Ap back to autonomous mode, I delete all de configuration and then I converting the Ap back to ligthweith and the ap can join the controller
Stephan Spittaler Tue, 12/29/2009 - 05:50
I had a similar issue with an AP not joining a controller which has recently been upgraded to version 6.0.182.0. While debugging I realized the message "Discarding discovery request in LWAPP from AP supporting CAPWAP" on the controller... While converting to autonomous mode and back to lightweight would resolve the issue, probably the easier way is to boot the AP with no network connection and sourced through an external power supply, deleting the lightweight images from the flash (leaving the recovery image on) and reloading the AP from the console - Clearing all the LWAPP config and setting the params manually - é voilà: registering at the controller and downloading its new lightweight image... Still, this is no solution for many, possible remote, APs, but as a workaround it's good enough.
