Cluster IP address thru L2L tunnel
Apr 27th, 2009
I have 3 windows 2003 terminal servers setup for load balance using Windows Network Load Balance Manager. IP addresses 192.168.1.14, 192.168.1.15, 192.168.1.16 Cluster IP 192.168.1.40 multicast.
I have a remote site connected via site to site VPN tunnel using Cisco ASA5510 devices, subnet 192.168.100.1. On the local LAN(192.168.1.0) I can get connected to terminal servers using the cluster IP, at the remote site I can not. At the remote site I can connect to each TS using the actual IP address, I can ping the cluster IP address or the dns name and get a response. Can anybody think of any reason why I can not connect using the cluster IP address?
servnj Fri, 05/01/2009 - 06:21
I have setup wireshark on my 192.168.1.0 subnet and setup a packet capture on the ASA5510. On the wireshark I see SYN packets coming in from my machine 192.168.100.102 to the cluster IP and I see SYN,ACK packets Src the cluster IP with the mac address of one of the terminal servers and the dst my IP address with the mac address of the ASA 5510. On the ASA5510 packet capture I only see the SYN packets from my machine coming in but no SYN,ACK packets going out. What happened to the SYN,ACK packets?
I did a packet capture when connecting to the actual IP address of the terminal server (Which Works) and compared the SYN,ACK packets from both and saw no difference.
