Rcv Frame Unknown DLCI
Apr 27th, 2009
Dear All, I would like to know what will cause this issue. it is still increasing in the counter. Thanks..
Rcv Frame Abort : 0
Rcv Frame Unknown DLCI : 781
Rcv Frame Last Unknown DLCI : 368
Rcv Frame Tagged FECN : 0
Rcv Frame Tagged BECN : 0
Giuseppe Larosa Mon, 04/27/2009 - 23:17
  • Hall of Fame,
    Founding Member
Hello Cody,
the FR switch is sending t your router frames with a DLCI not defined in your router's interface or subinterfaces.
This shouldn't be a big issue.
You may want to contact your FR provider to ask them to verify their equipment.
Hope to help
Giuseppe
