04-27-2009 09:02 PM - edited 03-06-2019 05:25 AM
Why I can not ping anywhere from Cat65.
No access-list filter icmp on Cat65.
04-28-2009 12:53 AM
Check your SVI interfaces are up check your static/dynamic routes
04-28-2009 04:46 AM
It is fail to ping even the clients on all directed connected interfaces.
04-28-2009 04:47 AM
post your config for review - remove sentitive information.
04-28-2009 05:03 AM
04-28-2009 05:08 AM
check
vlan access-map icmp 10
match ip address 194
action drop
vlan access-map icmp 20
match ip address 192
action forward
So see if the source/destination of the pings is allowed.
04-28-2009 05:31 AM
I was remove acces-list 194.Did not fixed.
Acess-list 192= permit ip any any
Do you think it will fix?
04-28-2009 05:34 AM
What is the source IP address you are using for the ping? what are the desitinations? Is it all VLAN's or just some?
04-28-2009 05:51 AM
From Cat65( not specify) or any VLAN's IP addresses to any hosts on(within) Cat65 VLANs.
04-28-2009 06:07 AM
Sorry this makes no sense.
let me ask you this - from a host on a any of the vlans can you ping the Cat?
When you ping a host from the cat using a source IP of the cat does this also fail?
04-28-2009 06:23 AM
I can not ping from hosts on any VLANs to Cat.
ping a host from the cat using a source IP of the cat does fail too.
Only hosts to any hosts(any VLANs) works fine.
04-28-2009 06:24 AM
check
action drop
action forward
04-28-2009 06:38 AM
I will try tomorrow due to I can not access to my customer cat now.
04-28-2009 06:11 PM
I take out this two vlan access-map.But problems is same- can not ping from cat.
I revise my previous email -
I can ping from hosts to cat.
04-28-2009 06:24 PM
Andrew,
I fix it this morning.I take out "mls qos". Thanks for your help anyway.
