ssh on router
Answered Question
Apr 27th, 2009
Hi all,
We have configured ssh on router and its working but, as telnet was used earlier We need to disable Telnet now unable to find the right solution. Do we need to disable line vty or ???
Please assist,
RB
Correct Answer by thotsaphon about 8 years 3 days ago
Raj,
Sorry , I missed reading your question.
Router(config)# line vty 0 15
Router(config)# transport input ssh
This would be fine. Not sure which version of IOS you are using.
HTH,
Toshi
Overall Rating: 5 (1 ratings)
rkcontrol Mon, 04/27/2009 - 23:06
This is my current config on line vty. still I can use both SSh and telnet.
line vty 0 4
exec-timeout 7 0
password 7 030752180500
transport preferred ssh
transport input none
Thanks for ur reply,
Rupesh Kashyap Mon, 04/27/2009 - 23:35
Do one thing, just add
Transport input ssh
Transport output ssh
I have tested, telnet is blocked.
rkcontrol Tue, 04/28/2009 - 21:33
Dear Rupesh,
I appreciate ur help on the subject, but unfortunately I am unable to get the solution as suggested, is there anything else beside line vty 0 4 config. I have tried both eg below. Still I can use both SSH and Telnet and are aunthenticated by ACS. Do suggest some other option.
line vty 0 4
exec-timeout 7 0
transport preferred none
transport input ssh
transport output ssh
line vty 0 4
exec-timeout 7 0
transport input ssh
rkcontrol Tue, 04/28/2009 - 22:06
Hi Toshi,
Infact I have referred the same doc from cisco.com and configured as mention. SSH is working fine but I need to disable telnet.
R01#sh ip ssh
SSH Enabled - version 1.99
Authentication timeout: 60 secs; Authentication retries: 3
Any other option,
Correct Answer
thotsaphon Tue, 04/28/2009 - 22:25
  • Gold, 750 points or more
Raj,
HTH,
Toshi
