Integrate CUCM 6.0 with CCME
Apr 27th, 2009
We have two international locations.
At one location (location 1) we have CUCM 6.0 & at the other location (location 2)we have CCME on 2800 router.Both locations are connected via 512K international MPLS link.
We want users behind CCME to use local PSTN & when the users want to call to location 2 extensions they use the international MPLS link & visa-versa.
1.How do we integrate the CCME with CUCM.What are the required parameters that need to be configured on CCME & CCM.
gogasca Mon, 04/27/2009 - 22:23
Hi Sack,
You can integrate it via SIP or via H323 because of the international link i would go for H.323.
You need to configure in cme dial-peers pointing to cucm and in cucm route oatterns and add an h.323 gw
if you browse our site there is some documents for this integration.
sachin_mon Mon, 04/27/2009 - 22:30
Hi Gonzalo,
Thanks for your prompt response.
Can you share some documents if you have to do the same.
