VPN client (4.9.01) disconnecting when wireless
Apr 27th, 2009
I use a macbook pro to connect to my company network via the cisco vpn client 4.9.01. While i am able to vpn in via my home wlan and hotspots, when using my wireless modem (vodafone mobile connect), i manage to log in for about 5 seconds, then then cisco vpn client disconnects saying "secure VPN connection terminated locally by the client. Reason 422: lost contact with the security gateway. check your network connection. This happens regardless of what gateway i use. The logs say the following:
Cisco Systems VPN Client Version 4.9.01 (0100)
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Mac OS X
Running on: Darwin 9.6.0 Darwin Kernel Version 9.6.0: Mon Nov 24 17:37:00 PST 2008; root:xnu-1228.9.59~1/RELEASE_I386 i386
Config file directory: /etc/opt/cisco-vpnclient
1 07:11:41.919 04/28/2009 Sev=Warning/2 CVPND/0x83400011
Error -28 sending packet. Dst Addr: 0x0AD337FF, Src Addr: 0x0AD33702 (DRVIFACE:1158).
2 07:11:41.920 04/28/2009 Sev=Warning/2 CVPND/0x83400011
Error -28 sending packet. Dst Addr: 0x0A2581FF, Src Addr: 0x0A258102 (DRVIFACE:1158).
3 07:11:41.920 04/28/2009 Sev=Warning/2 CVPND/0x83400011
Error -28 sending packet. Dst Addr: 0xAC106CFF, Src Addr: 0xAC106C01 (DRVIFACE:1158).
4 07:12:25.236 04/28/2009 Sev=Warning/3 CM/0x83100027
Adapter address changed from 10.47.1.30. Current address(es): 10.211.55.2, 10.37.129.2, 172.16.108.1.
5 07:12:30.241 04/28/2009 Sev=Warning/2 CVPND/0xC3400018
Privilege Separation: root operation failed.
6 07:12:30.243 04/28/2009 Sev=Warning/2 IKE/0x83000067
Received an IPC message during invalid state (IKE_MAIN:507)
7 07:12:31.235 04/28/2009 Sev=Warning/2 IKE/0x83000067
8 07:12:31.736 04/28/2009 Sev=Warning/2 IKE/0x83000067
9 07:24:15.248 04/28/2009 Sev=Warning/2 CVPND/0x83400011
10 07:24:15.249 04/28/2009 Sev=Warning/2 CVPND/0x83400011
11 07:24:15.249 04/28/2009 Sev=Warning/2 CVPND/0x83400011
12 07:24:35.745 04/28/2009 Sev=Warning/3 CM/0x83100027
Adapter address changed from 10.57.202.37. Current address(es): 10.211.55.2, 10.37.129.2, 172.16.108.1.
13 07:24:40.751 04/28/2009 Sev=Warning/2 CVPND/0xC3400018
14 07:24:40.753 04/28/2009 Sev=Warning/2 IKE/0x83000067
15 07:46:45.073 04/28/2009 Sev=Warning/2 CVPND/0x83400011
16 07:46:45.073 04/28/2009 Sev=Warning/2 CVPND/0x83400011
17 07:46:45.073 04/28/2009 Sev=Warning/2 CVPND/0x83400011
18 07:47:01.269 04/28/2009 Sev=Warning/3 CM/0x83100027
Adapter address changed from 10.49.6.116. Current address(es): 10.211.55.2, 10.37.129.2, 172.16.108.1.
19 07:47:06.276 04/28/2009 Sev=Warning/2 CVPND/0xC3400018
20 07:47:06.278 04/28/2009 Sev=Warning/2 IKE/0x83000067
