AS5300 does not change to Radius backup server
Hello, we have two radius servers <Radius_1_PUBLIC_IP> and <Radius_2_PUBLIC_IP> When the first shuts down, the AS5300 Gateway does not change to the backup server.
aaa group server radius H323-calls
server <Radius_1_PUBLIC_IP> auth-port 1812 acct-port 1813
server <Radius_2_PUBLIC_IP> auth-port 1812 acct-port 1813
aaa authentication login admins local
aaa authentication login remote group radius local
aaa authentication login h323 group H323-calls
aaa authorization exec h323 group radius
aaa accounting exec default start-stop group radius
aaa accounting connection h323 start-stop group radius
radius-server host <Radius_1_PUBLIC_IP> auth-port 1812 acct-port 1813 non-standard
radius-server host <Radius_2_PUBLIC_IP> auth-port 1812 acct-port 1813 non-standard
radius-server key 7 xxxx
I attach the complete configuration and show version.
irisrios Tue, 05/05/2009 - 08:35
Try to configure a proper radius secret for all radius servers or configure a global radius secret.
Hello, thank you very much for the response.
We have tried to configure a global shared key and local shared key:
radius-server host auth-port 1812 acct-port 1813 non-standard key 7
But the problem happens again.
These is a part of the debug of the gateway when we shut down the Radius1 (first choice) and has to switch to Radius2:
Feb 18 16:06:25.204 MET: RADIUS: Trying next server ( :1813,1812) for
id111
Feb 18 16:06:25.204 MET: RADIUS: Retransmit id 111
Feb 18 16:06:26.204 MET: RADIUS: Retransmit id 111
Feb 18 16:06:27.204 MET: RADIUS: Retransmit id 111
Feb 18 16:06:29.204 MET: RADIUS: Tried all servers.
Feb 18 16:06:29.204 MET: RADIUS: No valid server found. Trying any viable server
Feb 18 16:06:29.204 MET: RADIUS: No response for id 111
Feb 18 16:06:29.204 MET: %RADIUS-3-ALLDEADSERVER: Group radius: No active radius
servers found. Id 111.
I don't know if it's a bug, but the gateway marks as dead but when it tries next server it can't communicate with int. The problem happens exactly if the Radius2 is active and Radius1 is backup.
Any help would be great for us because we don't know what is happening.
