OS.2003.1.1 on HP DL320-G2 supported?
Apr 28th, 2009
Hello!
I am trying to install UCCX7 on one of my lab servers, which is a HP DL320 G2. This server is the hardware equivalent of the MCS-7825H-2266, which is supporting OS.2003.1.1. The only thing i have changed in the HW-configuration is that i replaced the original 40GB-HDD with an 120GB-HDD, as the installation wizard stated, that the 40GB is not supported, i need a 72,6 GB-HDD. But now the wizard says the 120GB is also not supported, i need the 72,6 GB one.
CUCM 6.x is working fine on this server with the 120GB-drive. Why isn't the OS-2003.1.1 working? I don't think that a 72,6GB IDE-HDD is currently existing.
ivillegas Tue, 05/05/2009 - 05:43
  • Silver, 250 points or more
This Cisco Unified Communications operating system requires a minimum of 72 GB of disk space on MCS-7835 and MCS-7845 servers and requires 80 GB of disk space on the MCS-7815 and MCS 7825 servers with SATA. If the installation process detects less than required disk space on the server, the installation aborts.
philippgrafl Tue, 05/05/2009 - 05:47
But in my case the installation process detects more space than required and aborts the installation.
The DL320G2 supports only IDE-HDD and no SATAs.
