HSRP Issue
Hello there,
I have 3 routers in my LAN network. R1, R2 and R3.
R2 <> R1 <> R3
At the same time, I have Layer 2 port channel connecting R2 and R3.
I have Vlan 1, 300, 500 and 700 on R2 and R3 routers with HSRP configured
HOwever, when layer 2 link between R2/R3 was down, all the VLANs were down and inaccessable.
Can I know why?
smothuku Tue, 04/28/2009 - 02:03
Hi ,
Can you send the configuration of both the routers.
jjchen978 Thu, 04/30/2009 - 00:20
do you have any other ports on R2 or R3 connected to vlan 1, 300, 500, 700 or any other ports running as trunk port other than the port channel between R2 and R3?
jjchen978 Thu, 04/30/2009 - 01:35
let me try to give my ideas. pardon me if my suggestion does not make sense. just trying to help and learn from all the experts here. =)
i was suspecting that because the only port (i.e. port channel trunk) associated to the vlans is down, thereby when your port channels is down, all your vlans is down.
maybe if you have other ports assigned to the vlans and the interface is up, your vlan might show as up.
jjchen978 Thu, 04/30/2009 - 02:01
if you do a show vlans, is there any ports associated to R2 GigabitEthernet2/0/1 or R3 GigabitEthernet2/0/1?
