ATA 186 behaving unreliably with Toshiba DP120F fax machines
Apr 28th, 2009
I have problems with Toshiba DP120 F fax machines receiving faxes via an ATA 186 and an H323 gateway. The gateway is configured with "Modem passthrough nse g711ulaw" and the ATA has the audiomode 0x00150015 and connectmode parameter 0x90000400. Has anyone else had problems with these devices in fax passthrough mode and solved the problem? The strange thing is that some of them seem to work fine and others do not - is there a known software issue with the device?
Overall Rating: 2.5 (2 ratings)
PETER NEGUS Tue, 04/28/2009 - 02:02
I should add that the fax machines connect fine, but the problem ones fall over and abort the call after receiving one or two pages.
riazshams Tue, 04/28/2009 - 08:02
guys,
same problem i am also facing .. i have ATA 186 configured with CCME 7.1 .. some time fax working fine and some time not receiving neither sending ... ATAs are integrated with Toshiba and Sharp fax machine ... on both of them i am facing same problem !!!!
can any one tell how to troubleshoot it ??
ivarnhagen Tue, 04/28/2009 - 11:26
also had fax problems on ATAs before. Try setting the send/recv rate on the fax to 9600 baud, and turn ECM off. This does the trick most of the time.
hth
riazshams Wed, 04/29/2009 - 09:08
hi ,
i tried to set 9600 baud on fax machine but no luck ... any other reason !!!!
chadlincoln Wed, 04/29/2009 - 09:20
  • Bronze, 100 points or more
Check for problems on the switchport interface connected to the ATA. Check for errors/collisions on all interfaces in the path between the two devices. So is this on-net faxing? Faxing from one ATA to another or from the PSTN to the ATA?
riazshams Fri, 05/01/2009 - 00:37
hi,
internal fax between ATA's are working fine .. but if some one send fax from PSTN or if i send fax to PSTN then i am facing problem .. some time fax are going some time not some time not going complete ... below is sh run of ccme ...
Building configuration...
boot-start-marker
boot system flash:c3845-adventerprisek9-mz.124-24.T.bin
boot-end-marker
no ip dhcp use vrf connected
ip dhcp excluded-address 172.100.1.1 172.100.1.20
ip dhcp pool voice
network 172.100.1.0 255.255.255.0
default-router 172.100.1.1
option 150 ip 172.100.1.2
no ip domain lookup
ip multicast-routing
no ipv6 cef
isdn switch-type primary-4ess
voice-card 0
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol cisco
h323
sip
registrar server expires max 3600 min 3600
voice class codec 1
codec preference 1 g711ulaw
voice translation-rule 1
rule 1 /^17380/ //
rule 2 /17380038/ /083/
voice translation-rule 300
rule 1 // /17380/
voice translation-profile PSTNIN
translate called 1
voice translation-profile PSTNOUT
translate calling 300
controller E1 0/2/0
framing NO-CRC4
pri-group timeslots 1-28
interface GigabitEthernet0/1
ip address 172.100.1.2 255.255.0.0
duplex auto
speed auto
media-type rj45
interface Serial0/2/0:15
no ip address
encapsulation hdlc
isdn incoming-voice voice
isdn bchan-number-order ascending
no cdp enable
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.100.1.1
ip http path flash:
tftp-server flash:ATA030204SCCP090202A.zup
control-plane
voice-port 0/2/0:15
translation-profile incoming PSTNIN
translation-profile outgoing PSTNOUT
mgcp fax t38 ecm
dial-peer voice 21 pots
destination-pattern 9[1-9].......
direct-inward-dial
port 0/2/0:15
forward-digits 8
dial-peer voice 100 voip
no modem passthrough
incoming called-number ...
dtmf-relay h245-alphanumeric h245-signal
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
no vad
telephony-service
max-ephones 240
max-dn 720
ip source-address 172.100.1.2 port 2000
auto assign 1 to 8
system message Your current options
load ata ATA030204SCCP090202A
time-zone 22
time-format 24
max-conferences 12 gain -6
call-forward pattern 1...
call-forward pattern 3...
call-forward pattern 4...
moh moh.wav
multicast moh 239.10.16.4 port 2000
web admin system name cisco password cisco
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern 3...
transfer-pattern 1...
transfer-pattern 4...
secondary-dialtone 9
create cnf-files version-stamp 7960 Apr 30 2009 08:36:02
ephone-template 1
softkeys idle Redial Newcall Cfwdall Dnd
ephone-template 2
softkeys idle Redial Newcall Dnd
ephone-dn 68
number 5
call-forward all 000
ephone-dn 69
number 100 secondary 17380100
label ATA
ephone-dn 70
number 110 secondary 17380110
label ATA
ephone-dn 71
number 029 seconday 17380029
label ATA
ephone-dn 72
number 043 secondary 17380043
label ATA
ephone-dn 73
number 122 secondary 17380122
label ATA
ephone-dn 74
number 129 secondary 17380129
label ATA
ephone 69
mac-address 0024.C40D.BF24
max-calls-per-button 2
type ata
button 1:69
ephone 70
mac-address 24C4.0DBF.2401
type ata
button 1:70
ephone 71
mac-address 0024.C40D.BD6C
button 1:71
ephone 72
mac-address 24C4.0DBD.6C01
type ata
ephone 73
mac-address 0024.C40D.C027
type ata
button 1:73
ephone 74
mac-address 24C4.0DC0.2701
type ata
button 1:74
Please reply urgently if there is any mistake in dial-peers !!!
riazshams Fri, 05/01/2009 - 01:16
one thing i forget to tell in above post, that i have tested out the analog line by replacing it from ATA to directly in FAx machine .. its working fine ... so it means there isnt any problem into analog line ...
i guess problem is in dial-peer of sending and receiving fax ... .
can any one tell via have alook on above config that where is the mistake ...
plz reply urgently and thanks in advance
chadlincoln Fri, 05/01/2009 - 05:36
Try putting this under your dial-peer voice 100 voip:
modem passthrough nse codec g711ulaw
dtmf-relay rtp-nte h245-alphanumeric
fax rate disable
Please rate if this helps.
riazshams Sat, 05/02/2009 - 13:39
Gents,
I have got resolved ATA working fine without configuring dial-peer and special commands for Fax or ATA's ...
actually i had uploaded the firmware of ATA into flash but after uploading i didnt reboot the system !!!! so yesterday i just reboot my system and all things started to work perfectly !!!!
thanks for all of guys for help and suggestion .. if some one wants tell me i can share the running config ....
paolo bevilacqua Sat, 05/02/2009 - 13:49
  • Hall of Fame,
    Founding Member
Check you E1 controller, you may also having slips, for which you need network-clock-participate and network-clock-select. The usual symptom is inability to send or recieve faxes made of many pages.
