CM5 Migration to CM7 with IP/Host name change
Apr 28th, 2009
Dear Sir,
I require to do the CM hardware and software migration, my step are following:
1) Backup exsiting CM5 configuration
2) Install CM5 OS and restore data
3) Upgrade to CM7 and Backup
4) Change the IP and hostname and Backup
I find that the TFTP file are missing in the Backup after change the IP and hostname, any special step I need to do first? I m sure the TFTP service is running.
Ayodeji oladipo... Tue, 04/28/2009 - 05:37
What do you mean the TFTP file is missing in backup?
Can yo u explain better? What steps did you use to change the IP and hostname
russ.kwong Tue, 04/28/2009 - 11:10
I do the backup with the DRT, when I do the first time (haven't change IP), the process in DRT have TFTP backup and save to the network location.
But I change the IP in Node1 and backup again, the process in DRT got no display at all.
I change the IP in the CM administration Server that fill, then change the IP in the CM OS admin page IP.
