Voice Vlan Access Map Question
Apr 28th, 2009
Hi:
I have a switch that has a data vlan configured and a voice vlan.
data vlan is 341
voice vlan is 546
Here is the config:
vlan 546
name Avaya_Phone_vlan546
vlan 341
name data_vlan
vlan access-map VOICE 10
action forward
match ip address Avaya_Phones
vlan access-map VOICE 20
action forward
match ip address NETWORK_SERVICES
vlan filter VOICE vlan-list 546
vlan 546
ip access-list extended Avaya_Phones
remark ACL for Avaya traffic
permit udp any range 10000 14001 any range 10000 14001
permit tcp any range 1024 65535 any range 61440 61444
permit udp any range 10000 14001 any eq 5005
permit udp any range 1024 65535 any eq 1719
permit udp any eq 1719 any range 1024 65535
permit tcp any range 1024 65525 any range 1719 1720
permit tcp any range 1719 1720 any range 1024 65525
permit udp any eq 68 any eq 67
permit udp any range 1024 5000 any eq 53
permit tcp any range 1024 5000 any eq 411
permit tcp any range 1024 5000 any eq 80
permit tcp any range 1024 5000 any eq 443
permit tcp any any eq 80
permit tcp any any eq 81
permit udp any any eq 161
permit udp any range 1024 5000 any eq 514
permit tcp any range 1024 5000 any eq 50002
permit udp any any eq 50000
permit udp any any eq 69
permit icmp any any
ip access-list extended NETWORK_SERVICES
remark PIM/HSRP/DHCP
permit pim any any
permit tcp any 10.76.160.0 0.0.31.255 eq 22
permit tcp any 10.76.192.0 0.0.31.255 eq 22
permit tcp any 10.76.160.0 0.0.31.255 eq 21874
permit tcp any 10.76.192.0 0.0.31.255 eq 21874
permit tcp 10.76.160.0 0.0.31.255 eq 22 any
permit tcp 10.76.192.0 0.0.31.255 eq 22 any
permit tcp 10.76.160.0 0.0.31.255 eq 21874 any
permit tcp 10.76.192.0 0.0.31.255 eq 21874 any
permit tcp host 10.76.171.1 any eq smtp
permit tcp host 10.76.179.1 any eq smtp
permit tcp host 10.76.171.1 any eq domain
permit tcp host 10.76.179.1 any eq domain
permit udp host 10.76.179.1 any range 1024 65525
permit udp host 10.76.171.1 any range 1024 65525
permit udp any range 1024 65525 host 10.76.179.1
permit udp any range 1024 65525 host 10.76.171.1
permit udp any eq 1985 any eq 1985
permit udp any eq bootps any eq bootpc
permit udp any eq bootps any eq bootps
permit udp any eq domain any
permit tcp any eq www any
permit icmp any 10.76.160.0 0.0.31.255 echo
permit icmp any 10.76.160.0 0.0.31.255 echo-reply
permit icmp any 10.76.192.0 0.0.31.255 echo
permit icmp any 10.76.192.0 0.0.31.255 echo-reply
permit icmp 10.76.160.0 0.0.31.255 any echo
permit icmp 10.76.160.0 0.0.31.255 any echo-reply
permit icmp 10.76.192.0 0.0.31.255 any echo
permit icmp 10.76.192.0 0.0.31.255 any echo-reply
permit icmp any any ttl-exceeded
deny ip any any log
interface vlan546
ip address 10.76.185.251 255.255.254.0
ip helper-address 10.76.171.1
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-dense-mode
service-policy input user-marking
no shut
What I dont understand is that the vlan filter (vlan access map) is applied to the Avaya phone vlan, yet the traffic its filtering is the kind of traffic that would be generated by a PC, not a phone, like http or https. Why is that?
The PC would indeed be connected to the phone and the phone to the switch. The PC would be on the data vlan and the phone on the voice, of course. So, shouldnt the vlan access map be applied to the data vlan?
Marwan ALshawi Tue, 04/28/2009 - 04:58
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, December 2015
if you are using phone not cisco
the voice vlan will not be used by the phone
this voice vlan wil be negotiated with IP phone using CDP only cisco IP support CDP
becasefull with this !!!
ex-engineer Tue, 04/28/2009 - 05:34
Marwan:
Thats a good point. I did think of that, actually. I will address that with them.
In this case, they would have to configure a dot1q trunk and allow the data and voice vlan, right?
Also, what do you think of my original question regarding the vlan access map?
Marwan ALshawi Tue, 04/28/2009 - 14:33
acutlly vlan access map
also known as vlan ACL VACL
it works like ACL
but it helps u to filter traffic within ur vlan
let say u want to block traffoc between tow hosts within the same vlan VACL will do it for you
