LMS 3.1 - Sync between DCR/CM and RME sometimes doesn't work
Apr 28th, 2009
Hi there,
within our network we don't use the autodiscovery mechanism and add devices manually.
We discovered that after running a while new (manually) added devices aren't added/sync'd between DCR and RME (after CM DataCollection.
Doing a manual RME-Device-Resubmit results in devices not inventory and configuration-collected.
Only restarting the whole LMS-Application correctly manages the devices in RME.
Is this a know problem?
Thanks for your feedback
Lothar
lo.mueller Tue, 04/28/2009 - 03:54
To append:
- The devices show up in RME Device-Management under Pending devices.
But they will never be "managed" by RME.
digisridhar Thu, 04/30/2009 - 00:27
What version of LMS do u have. Also what is the hostname of the LMS Server. Send the details of the version of all modules also. Any screenshots would be helpful..
Sridhar
