Some Router Errors
Apr 28th, 2009
I have 2811 router and i am receiving the following errors:
%SYS-2-INTSCHED: 'suspend' at level 3 -Process= "Exec", ipl= 3, pid= 168, -Trac
eback= 0x4167DBF0 0x40064070 0x42CF8DEC 0x43386F50 0x43387004 0x41E98D10 0x41E99
C7C 0x43386F04 0x43387004 0x41E90A04
000852: *Apr 27 07:34:47.819 UTC: %IP_VFR-4-FRAG_TABLE_OVERFLOW: Dialer1: the fr
agment table has reached its maximum threshold 16
001634: *Apr 27 11:01:47.391 UTC: %SYS-3-LOGGER_FLUSHING: System pausing to ensu
re console debugging output.
%SCHED-7-WATCH: Attempt to enqueue uninitializ
ed watched queue (address 0). -Process= "Exec", ipl= 0, pid= 3, -Traceback= 0x4
167DBF0 0x42CFE17C 0x42A1EFDC 0x42A5D5E4
any help on the above issues will be highly appreciated.
Joseph W. Doherty Tue, 04/28/2009 - 04:13
The Tracebacks might indicate a software defect. You could either present them to TAC or perhaps first try a different IOS release or version.
johnlloyd_13 Tue, 04/28/2009 - 04:16
According to Cisco.com's online error message decoder tool (http://www.cisco.com/pcgi-bin/Support/Errordecoder/index.cgi):
%IP_VFR-4-FRAG_TABLE_OVERFLOW: [chars]: the fragment table has reached its maximum threshold [dec]
The number of datagrams being reassembled at any one time has reached it maximum limit.
Recommended Action: Increase the maximum number of datagrams that can be reassembled by entering the ip virtual-reassembly max-reassemblies number command, with number being the maximum number of datagrams that can be reassembled at any one time.
Related documents- No specific documents apply to this error message.
%SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
Debugging or informational messages are being generated faster than they can be displayed on the console. To ensure that the messages could be seen, the rest of the system has been paused until the console output catches up. This condition might cause an interruption in time-critical operations (for example, maintaining an ISDN link).
Recommended Action: To reduce the number of debugging or informational messages that are displayed, use conditional debugging and turn off console logging. Enter the no logging console guaranteed command, or turn off link-state messages for some other interfaces.
%SCHED-7-WATCH: Attempt to [chars] uninitialized watched [chars] (address [hex]).
A process can register to be notified when various events occur. An attempt was made to register for an event without first creating the data structure for that event.
Recommended Action: If this message recurs, copy the message exactly as it appears on the console or in the system log. Research and attempt to resolve the issue using the tools and utilities provided at http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs. If you still require assistance, open a case with the Technical Assistance Center via the Internet at http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the information you have gathered. Attach the following information to your case in nonzipped, plain-text (.txt) format: the output of the show logging and show tech-support commands and your pertinent troubleshooting logs.
A processes can register to be notified when various events occur. This message indicates that an attempt was made to register for an event without first creating the data structure for that event.
http://www.cisco.com/tac. With some messages, these tools and utilities will supply clarifying information. Search for resolved software issues using the Bug Toolkit at http://www.cisco.com/pcgi-bin/Support/Bugtool/launch_bugtool.pl. If you still require assistance, open a case with the Technical Assistance Center via the Internet at
http://www.cisco.com/cgi-bin/front.x/case_tools/caseOpen.pl, or contact your Cisco technical support representative and provide the representative with the gathered information.
