04-28-2009 05:06 AM - edited 03-04-2019 04:33 AM
I have add static route for network 10.64.2.0 on router.
But this route is showing 7 times instead of 1 under show ip route static .
why it is getting so .
For reference find the attachment
04-28-2009 05:55 AM
Hello Suryakant,
what router model is this ?
what IOS image ?
post a sh ver
Hope to help
Giuseppe
04-28-2009 07:55 AM
hi Giuseppe
Thanks for your quick reply.
Here is output of sh version.
Router#sh version
Cisco IOS Software, 3800 Software (C3825-ADVENTERPRISEK9-M), Version 12.4(9)T7, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 10-Jan-08 18:20 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
Router uptime is 3 weeks, 2 days, 17 hours, 22 minutes
System returned to ROM by reload at 03:55:39 IST Sun Apr 5 2009
System restarted at 03:57:14 IST Sun Apr 5 2009
System image file is "flash:c3825-adventerprisek9-mz.124-9.T7.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 3825 (revision 1.2) with 225280K/36864K bytes of memory.
Processor board ID FHK1126F1PQ
2 Gigabit Ethernet interfaces
16 Serial interfaces
8 Channelized E1/PRI ports
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
479K bytes of NVRAM.
62720K bytes of ATA System CompactFlash (Read/Write)
04-28-2009 08:10 AM
Hello Suryakant,
try to follow Edison's suggestion
do clear ip route *
then re-issue
sh ip route static
other suggestion:
what is the output of
sh ip route
this is just to understand if is a problem in the output of sh ip route static.
If you still see multiple entries for the same static route try to reload the router.
Hope to help
Giuseppe
04-28-2009 06:41 AM
That's not a normal behavior and most likely you've hit a bug. Your RIB seems to be corrupted so either
clear ip route * or reboot the router if possible.
HTH,
__
Edison.
