Remote Branch VoIP solution
bcoon
We need to have a VoIP solution for a small branch (under 20) office. We currently have Call Manager set up at our main site. Remote site will be VPN Site-to-sited with asa.
5 Replies 5
chadlincoln
Level 3
Level 3
What is it about the project that you need input on? Design?
try with a UC520
java
if this helps, please rate
java
Deisgn, yes would be greatful
Well, 20 users remote across a VPN. You'll need an ASA/router to terminate the VPN between the two sites. You'll need phones and DLU's if you don't have enough DLU's already. I'd set them up for g.729. Do they have their own gateway at the other end? What analog needs to they have? Do all users need voicemail? Do you have enough voicemail licenses?
Thsi is from scratch. we will have an asa out there with a pipe back to the main office. main purpose is to switch a sip trunk at 12 hr block intervals from north america to australia to cover euro calls coming in 24x7.
