Managing 5520 Failover Cluster
Apr 28th, 2009
I've configured a active/passive cluster with a couple of 5520s. When making changes to the cluster, I don't worry about primary/secondary or active/standby, I simply use the ip address of the active ASA.
Is this ok/normal/best practice? Does it matter that right now I'm logging into the secondary - active ASA to make changes?
Thanks!
Overall Rating: 5 (1 ratings)
Collin Clark Tue, 04/28/2009 - 11:58
Make changes to the primary device and you'll be OK. Actually you'll get an error if you're on the back up device and you try and make a change.
ASA# config t
**** WARNING ****
Configuration Replication is NOT performed from Standby unit to Active unit.
Configurations are no longer synchronized.
ASA(config)#
Hope that helps.
