Unity Connection 7.0 - Alternate Extension Bulk Add/Edit
Answered Question
Apr 28th, 2009
I have a customer that has roughly 1,000 sales folks that are going to use their cell phones as alternate extensions in their UCON 7.0(2) system. The plan is to use VM password by-pass so they can be as hands-free as possible from their cell phones along with voicemails being tagged when leaving a message to another user on the system from their cell.
The problem is that I don't see anything in Bulk Add or Edit or anything in the import that would allow us to add these numbers easily for all of these users.
Perhaps I'm missing something available from ciscounitytools.com or an option in the built-in functions to accomplish this?
Thanks in advanced for the help.
Correct Answer by Ginger Dillon about 7 years 12 months ago
Hi -
Have you seen this section that discusses the Bulk Administration Tool - look at the optional fields for the csv import - http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_mac/guide/7xcucmacappa.html#wp1013626
Regards, Ginger
Correct Answer by Rob Huffman about 7 years 12 months ago
Hi Brian,
Have you looked into using BAT?
BAT> Update> Users With Voice Mailboxes
Extension_Alt1
The first alternate extension for the user.
Any combination of ASCII alphanumeric characters, from 1 to 40 characters long.
Updating User Accounts
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_mac/guide/7xcucmacappa.html#wp1043120
Hope this helps!
Rob
Overall Rating: 5 (2 ratings)
Correct Answer
Rob Huffman Tue, 04/28/2009 - 07:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Brian,
Extension_Alt1
Hope this helps!
Rob
