Is this back out plan statement wrong? (ospf redistribution)
Answered Question
Apr 28th, 2009
For example, imagine the following configuration to add a specific aggregate-address:
router bgp 1000
address-family ipv4 vrf MYTEST
redistribute ospf 1 vrf MYTEST route-map OSPF1_REDISTR
aggregate-address 1.1.1.0 255.255.255.0 summary-only
no auto-summary
end
wri mem
Then Documented roll-back plan is below. I think the line marked below is incorrect?
router bgp 1000
redistribute ospf 1 vrf MYTEST match internal external 1 external 2 <<<<<======Wrong?
no aggregate-address 1.1.1.0 255.255.255.0 summary-only
exit
end
wri mem
Correct Answer by Giuseppe Larosa about 7 years 9 months ago
Hello Marlon,
if the objective of the rollback action is only to remove the aggregate address the rollback can be:
router bgp 1000
if the rollback action includes the removal of the redistribute statement I would the following:
router bgp 1000
no redistribute ospf 1 vrf MYTEST route-map OSPF1_REDISTR
the reason for this is that I've seen that removing a redistribute ... route-map creates an entry without the route-map so it is better to remove twice.
About the suggested rollback:
this depends on what is the objective and on how the route-map is defined.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Tue, 04/28/2009 - 08:16
Hello Marlon,
router bgp 1000
router bgp 1000
Hope to help
Giuseppe
