VPN UP but the Vlan interface do not ping
Apr 28th, 2009
I have configured an ezvpn beetween Cisco 851 and ASA 5520. The vpn is UP but i can't ping the C851 vlan interface.
There is nothing connecte to the routeur. Is the router only forward paquets to the vlan interface if the LAN interface is up ?
Who can i configure the routeur to always responding event nothing connected to lan interface ?
Thanks for respons
dsweeny Tue, 05/05/2009 - 08:50
If you enabled Easy VPN, you cannot add or delete VLAN interfaces, nor can you edit the security level or interface name. We suggest that you finalize your interface configuration before you enable Easy VPN.
