UDLD
Apr 28th, 2009
Hi all
am i right in saying this is enabled on GE fiber ports by default and switched off on copper ports by default?
should I only enable this on my L3 links between my switces ? and leave it off everywhere else ?
Jerry Ye Tue, 04/28/2009 - 08:15
  • Cisco Employee,
Hi Carl,
UDLD is disabled on all port by default.
I will enabled all the ports with aggressive mode (it will error disabled when it detect unidirectional link).
HTH,
jerry
Jerry Ye Wed, 04/29/2009 - 07:46
  • Cisco Employee,
In the global config mode, use udld aggressive to enable UDLD aggressive to all ports.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_see/command/reference/cli3.html#wp1590243
If you would like to enable it per port based, use udld port aggressive to enble it per port.
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_see/command/reference/cli3.html#wp1921491
HTH,
jerry
