problem while uploading larger size files
Apr 28th, 2009
We have an ASA 5540 firewall running with Version 8.0(4) . Now we are facing problem while uploading files(larger than 2 mb) to one of the server which is located inside network over the internet. Application team are performing the same thru http application.They can easily upload the files which are smaller than 1 MB. Funnier part is that they were able to do the same before, since last 3 weeks they are facing this issue. I know most probably this problem is not related to ASA but when our application team contacted Oracle TAC they suggested to check the firewall settings. Did any one face this problem before ? appreciate your timely responce for solving this issue.
thnks
