Warning message
Giuseppe Larosa Tue, 04/28/2009 - 10:08
  • Hall of Fame,
    Founding Member
Hello Hsin,
if you don't use mpls autoroute announce you can decide what traffic you put in a mesh of MPLS TE tunnels.
This can be done by using static routes or combining them with BGP (using per service next-hop loopbacks).
Then, another matter is the volume of traffic you put over an MPLS TE tunnel: there is no real time effective CAC but CAC is performed on RSVP TE reversations.
In other words if a tunnel declares a bandwidth of 2 Mbps you can still put 20 Mbps of traffic over it!
It is not like it has been on ATM.
Hope to help
Giuseppe
Hsin An Chen Tue, 04/28/2009 - 16:46
Thanks ^ ^
if i used per service next-hop loopbacks.
Does it use with FRR ?
and can you give me the document ?
