Resource Reports group calculating wrongly?
Apr 28th, 2009
I'm using a regular expression to filter data for reports:
(( date_time > '20/Apr/2009 23:59:59') and ( date_time <= '27/Apr/2009 23:59:59'))
When this filter is used for reports under group Resource, it show a value of total 57.55 G . When used for other reports like overview or Date reports it shows 31.87 for total. I cannot explain this difference and i do think the problem is in group Resource reports. Anyone facing this problem or has any idea?
I'm using Sawmill 7.2.15 to extract data
jowolfer Wed, 05/27/2009 - 18:51
ardi_80,
I'm not sure what would be causing this discrepancy.
The first thing I recommend is upgrading to Sawmill for IronPort 7.3. This is the latest build available and has quite a few changes and optimizations to it.
After upgrading, if you are still experiencing the issue, I recommend filing a support ticket to have the specific data looked into further.
