extra 10/100 port on my 7206 xvr
Answered Question
Apr 28th, 2009
I have a 7206 vxr router with a dual 10/100 ethernet port. I just found out that I'll need an extra port on a router. can i buy a separate appliance with gigaethernet port(s) and connect on an empty slot? how is that appliance called?
Correct Answer by Jerry Ye about 7 years 9 months ago
You can try the 7200 Port Adapter (Cisco Part number PA-GE). However, these are fiber ports and require to have GBIC installed. You will need to have NPE-300 or above processor.
http://www.cisco.com/en/US/products/hw/modules/ps2033/products_data_sheet09186a0080091ce7.html
If you only need 100Mb copper ports, you can try PA-2FE-TX.
http://www.cisco.com/en/US/prod/collateral/modules/ps2033/ps2546/product_data_sheet09186a0080091c92.html
HTH,
jerry
Overall Rating: 5 (1 ratings)
Correct Answer
Jerry Ye Tue, 04/28/2009 - 09:08
HTH,
jerry
Joseph W. Doherty Tue, 04/28/2009 - 11:02
For a different option, you could also purchase an inexpensive L2 switch (e.g. 8 port 2960) that supports VLAN trunking and fan out one of your 7206 ports that way.
