Kenneth Mohammed Tue, 04/28/2009 - 09:23
  • Silver, 250 points or more
Im assuming that you are referring to an MGCP controlled PRI. The significant digits setting will be on the gateway configuration page in CUCM. If you want to verify how many digits the service provider is sending, you need to go into the gateway and issue a "debug isdn q931" and "term mon" to get this info.
Hope that helped, if so please rate.
Kenneth Mohammed Tue, 04/28/2009 - 09:58
Anytime, however, don't forget to rate helpful posts.
