Error contacting Host through VPN
I would swear this worked at one point. I have a corporate office, and I have IPSec tunnels out to my outside offices. The corporate office has an ASA5510, and most of the remote offices are running off of Pix506s, one office has an ASA5505.
When anyone connects through WebVPN, using AnyConnect or not, they can contact any of the cifs shares for servers inside the corporate office. They cannot, however, contact cifs shares on servers that are in the remote offices.
TECH SUPPORT Tue, 05/19/2009 - 07:32
I have had success in configuring something similar before, admittedly only WEBVPN . The issue I had was the source IP for your traffic attempting to traverse the IPSEC tunnel to access the cifs share is that of the public interface of the ASA. If you include that IP address as part of your encryption it should work. ie add another access-list line to encrypt traffic with a source of your public ip to the private LAN at the other end of the tunnel and the reverse on the remote ASA.
I hope this helps
Chris
[email protected]
