MGCP Overflow - network disconnect codes
Apr 28th, 2009
  • Silver, 250 points or more
I`ve set up a RL with MGCP circuits overflow for each other- circuit 1 Private Network, circuit 2 PSTN. The private network circuit is just a QSig link to another router which uses H323 to another telephone.
system.
1st choice CCM>>>>>MGCP>>>>>GW/H323>>>>ANOTHER TELEPHONE SYSTEM
2nd choice in the RL is CCM>>>>MGCP>>> PSTN
I want that if the H323 circuit is busy , not available to overflow to the Second choice . The 1st choice MGCP circuit receives the correct info. "channel unavailable, user busy " etc as I`ve added the sidn network- disconect 34, or isdn disconnect-code 34 but does not re-route- should the response be passed back to CCM and should it re-route? I`ve also set the flag for stop routing on busy to false it still failed- Any ideas- is it jsut for H323 which does act on the "Stop routing flag"
thanks
