corporate directory in ccm 6.0 customization
user-cisco
hi all
i'm wondering if this is supported...
we have 3 different clients using same callmanager 6.1 cluster, i'm looking for a way if i can configure it so that clientX users will be able see and access clientX only corporate directory and
clientY users will be able see and access clientY only corporate directory
and
clientZ users will be able see and access clientZ only corporate directory
and can i rename corporate directory to something like clientX directory?
if this is not supported is there any 3rd party application can do this?
please advise
thx
Jaime Valencia
this would mean creating your own scripts for each company, then adding a field on each AD user to filter them (or look only into an OU) and also manually writing down the directory url on each sepMAC.cnf.xml since the only one is global config and affects ALL config files. Also all this on a separate web server.
this is supported but you would need DEV support contract for this.
java
if this helps, please rate
java
thanks java, is there any 3rd party application can do the job?
