04-28-2009 12:18 PM - edited 07-03-2021 05:30 PM
I setup an 1240 radio with the following configuration but I don't know why it is not working ⦠I'm getting a authentication error. I will appreciate your help.
Thanks.
aaa new-model
aaa group server radius rad_eap
server 192.168.10.111 auth-port 1645 acct-port 1646
â¦
â¦
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 vlan-name blue vlan 100
dot11 vlan-name red vlan 200
dot11 ssid blue
vlan 100
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
â¦
â¦
username Cisco password 7 â¦â¦
â¦
â¦
interface Dot11Radio0
encryption vlan 100 mode ciphers tkip
encryption vlan 200 mode ciphers tkip
ssid blue
ssid red
station-role root
â¦
ip radius source-interface BVI1
radius-server local
no authentication eapfast
no authentication mac
nas 192.168.10.111 key 0 Cisco
user Cisco password 0 Cisco
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.10.111 auth-port 1645 acct-port 1646 key 0 Cisco
radius-server vsa send accounting
â¦
â¦
wlccp ap username Cisco password 0 Cisco
wlccp wds priority 254 interface BVI1
debug output:
*Mar 1 00:24:11.155: WDS: WLCCP_TYPE_AAA (START) rcvd, Org = 0040.9653.d356, Rsp = 001d.7097.b8fa, Req 0040.9653.d356, id 1 auth 4 key 0
*Mar 1 00:24:11.156: WDS: WLCCP_TYPE_AAA (EAPOL) sent with Source IP = 192.168.10.111, Org = 001d.7097.b8fa, Rsp = 0040.9653.d356, Req 0040.9653.d356, auth 4, key 0
*Mar 1 00:24:11.156: WDS: WLCCP_TYPE_AAA (START) rcvd, Org = 0040.9653.d356, Rsp = 001d.7097.b8fa, Req 0040.9653.d356, id 1 auth 4 key 0
*Mar 1 00:24:11.157: WDS: WLCCP_TYPE_AAA (EAP Request) rcvd, Org = 0040.9653.d356, Rsp = 001d.7097.b8fa, Req 0040.9653.d356, id 2 auth 0 key 0
*Mar 1 00:24:11.157: WDS: WLCCP_TYPE_AAA (EAPOL) sent with Source IP = 192.168.10.111, Org = 001d.7097.b8fa, Rsp = 0040.9653.d356, Req 0040.9653.d356, auth 4, key 0
*Mar 1 00:24:11.161: WDS: WLCCP_TYPE_AAA (EAP Request) rcvd, Org = 0040.9653.d356, Rsp = 001d.7097.b8fa, Req 0040.9653.d356, id 3 auth 0 key 0
*Mar 1 00:24:11.162: WDS: WLCCP_TYPE_AAA (EAP Request) rcvd, Org = 0040.9653.d356, Rsp = 001d.7097.b8fa, Req 0040.9653.d356, id 4 auth 0 key 0
*Mar 1 00:24:11.163: WDS: WLCCP_TYPE_AAA (EAPOL) sent with Source IP = 192.168.10.111, Org = 001d.7097.b8fa, Rsp = 0040.9653.d356, Req 0040.9653.d356, auth 4, key 0
*Mar 1 00:24:11.163: WDS: DOT11_AAA_FAILURE ...
*Mar 1 00:24:11.163: WDS: WLCCP_TYPE_AAA (FINISH) sent with Source IP = 192.168.10.111, Org = 001d.7097.b8fa, Rsp = 0040.9653.d356, Req 0040.9653.d356, auth 4, key 0
*Mar 1 00:24:11.164: WDS: DOT11_AAA_FAILURE ...
*Mar 1 00:31:47.953: dot11_auth_dot1x_run_rfsm: Executing Action(SERVER_WAIT,SERVER_FAIL) for 001d.7097.b8fa
*Mar 1 00:31:47.954: dot11_auth_dot1x_send_response_to_client: Forwarding server message to client 001d.7097.b8fa
*Mar 1 00:31:47.954: EAPOL pak dump tx
*Mar 1 00:31:47.954: EAPOL Version: 0x1 type: 0x0 length: 0x0004
04-28-2009 01:39 PM
What errors if any show up in the radius server logs?
04-28-2009 01:47 PM
The radius is local. the ap is the radius server.
