cisco 5400 isdn error disc code=0x29, disc text=Temporary failure!!!
I am having a small problem with our Cisco 5400 device, I have 5 T1 lines from Verizon all in a nfan group for some reason i am getting the following error:
disc subsys=ISDN, disc code=0x29, disc text=Temporary failure
on the call log, i have look it up on the site and get the following:
29 1D Facility rejected Facility identification (Note 1)
The facility requested by the user cannot be provided by the network.
also my telco says the following:
I see 2 dicrepencies on cust ss7 msg:(1) octet 18 Calling party's category parameter should be (10) ordinary calling subsriber(2) octet 37 ISUP Calling party number parameter Numbering Plan should be (1) ISDN (Telephony) numbering plan (ITU-T Rec. E.164, E.163).
I know his talking about the isdn map address but i think i got it right.
here is my config:
trunk group 60
hunt-scheme sequential both up
interface Serial6/3:23
no ip address
encapsulation hdlc
trunk-group 60
isdn switch-type primary-dms100
isdn incoming-voice modem
isdn map address . plan unknown type unknown
isdn T310 40000
isdn sending-complete
isdn ie oli 37
no cdp enable
wtild1#sh isdn nfas group 1
The primary D is Serial6/3:23.
The backup D is Serial7/4:23.
The NFAS member is Serial6/4:23.
The NFAS member is Serial6/5:23.
The NFAS member is Serial7/5:23.
There are 5 total nfas members.
There are 118 total available B channels.
The primary D-channel is DSL 3 in state IN SERVICE
The backup D-channel is DSL 12 in state STANDBY
The current active layer 2 DSL is 3.
and the full log error:
436xxx: Apr 28 21:15:27.901: %CALLTRKR-6-CALL_RECORD: ct_hndl=295xxx, service=None, origin=Originate, category=Modem, DS0 slot/port/ds1/chan=6/3/3/23, called=34xxxxx, calling=702xxxxx, resource slot/port=(n/a)/(n/a), userid=(n/a), ip=, account id=(n/a), setup=04/28/2009 14:14:14, conn=0.00, phys=0.00, service=0.00, authen=0.00, init-rx/tx b-rate=0/0, rx/tx chars=0/0, time=0.09, disc subsys=ISDN, disc code=0x29, disc text=Temporary failure------> there is that error again.....I have many many of these......:(
any idea guys Please?
thank in advance.
htarra Tue, 05/05/2009 - 08:15
This is because the call was disconnected due to a network failure. This code appears for some long distance providers if the hunt sequence is incorrect. PRI lines must be set up for a flex hunt sequence (not a float hunt sequence).
