CCVP Pre req
Apr 28th, 2009
Hi..!!
i've booked my CCNA examination on 20th of may 2009. i want to proceed to the CCVP track(if cleared the CCNA examination) my question is.
before 23rd of june this year there are two options available for between the pre reqs of CCVP which iare either do CCNA, or CCNA voice. if i'll clear any one CCVP paper before 23rd of june will i still have to take the CCNA voice examination for taking the rest of the examinations of ccvp track.
and my second question is is ccna is the pre req of CCNA voice..??
ccbootcamp Tue, 04/28/2009 - 14:25
Yes, CCNA is a pre-req for CCNA Voice. I believe you have to complete your CCVP before June 23rd if you don't want to also take the CCNA Voice exam - but I could be mistaken with this. Open a case with the certification folks to verify this.
For CCVP after june 23rd, you will need BOTH the CCNA AND CCNA Voice.
hth,
Brad Ellis
www.ccbootcamp.com
(Please rate this post if it helps)
