Nokia dual-phone config with LEAP
Apr 28th, 2009
I'm trying to config nokia E60 with cisco Callconect with Leap.
In WLC (4.2.172) I have configured in WLAN Profile , WPA+WPA2-> WPA Policy and TKIP -> CCKM.
I'm trying to use Local Eap, i have defined user and password in controller.
In nokia device i only active EAP-LEAP profile and
The Nokia Phone :
-Connection name : VoWLAN
-Databearer : Wireless WAN
-WLAN netw. name: TEST
-Network status: Broadcast
-WLAN netw. mode: Infrastructure
-WLAN security mode: 802.1x
-WLAN security settings :
--WPA mode: EAP
--EAP plug-in settings:
---EAP-LEAP (select only this, put in the higher position and disable all the others) :
---EAP-LEAP Configuration :
----User name: [Local Eap wlc user name]
----Prompt password: No
----Password: [ Local Eap wlc password]
Phone is not assossiating with WLAN, is that configuration supported? I have forgoted something?
Overall Rating: 5 (1 ratings)
etmarcof Wed, 04/29/2009 - 14:10
Hi Leolaohoo,
Thanks a lot,I've been looking for a while for a Design Guide for Nokia phones made by Cisco.
Unfortunetelly didn't solve my problem. My configuration for LEAP is equal to the configuration sugested by the design guide but phone didn't associate. I have only one thing diferent. I don't have External radius server i'm using Local Eap authentication of WLC.
Anyone has more suggestions?
Best Regards,
