SNMP-server view
Apr 28th, 2009
  • Bronze, 100 points or more
Hi All,
I see some autonomous AP in having the config
snmp-server view xxx mib-2 included,
snmp-server community 123 view xxx RO
Can somebody tell me what is the snmp-server view command for?
NikhiL
ericgarnel Wed, 04/29/2009 - 05:01
  • Gold, 750 points or more
Per Cisco, it a means of controlling snmp access
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094489.shtml
"The Setup SNMP view command can block the user with only access to limited Management Information Base (MIB). By default, there is no SNMP view entry exists. This command is configured at the global configuration mode and first introduced in Cisco IOS Software version 10.3. It works similar to access-list in that if you have any SNMP View on certain MIB trees, every other tree is denied inexplicably. However, the sequence is not important and it goes through the entire list for a match before it stops."
A good link for snmp
http://www.netcraftsmen.net/welcher/papers/snmprouter.html
nikhilcherian Wed, 04/29/2009 - 06:23
Eric,
That was the apt reply I wanted, thanks for the same
NikhiL
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
