No logging console
Answered Question
Apr 28th, 2009
Can I get the meaning for the cmd
No logging console
No loggin Monitor
Awaiting reply
Correct Answer by Edison Ortiz about 8 years 1 month ago
The first message turns off logging to the console connection. If you are connected to the device via a console connection, all messages are sent to the screen. This can also be seem as a security risk (leaving it on) as having a console connection opened and having this command enabled can potentially spike up the CPU and cause a DoS.
The second command disables logging messages to the terminal lines with monitor on. For instance, you telnet to the device and want to view messages not available to vty, you type the command terminal monitor. This allows you to see messages that you otherwise will be missing under a normal telnet session. Messages sent to the monitor session have the same security level as the ones sent to the console, so many engineers assumed they are switching to a console connection which they aren't.
HTH,
__
Edison.
Overall Rating: 4 (2 ratings)
cisco_lad2004 Wed, 04/29/2009 - 03:59
  • Gold, 750 points or more
it will stop logging messages popping up while you are in middle of configuring. it can be annoying to keep on being interupted with messages while typing...shame it cant be done with colleagues :-)
Correct Answer
Edison Ortiz Wed, 04/29/2009 - 05:35
  • Hall of Fame,
    Founding Member
HTH,
__
Edison.
rkcontrol Wed, 04/29/2009 - 22:01
Thanks Edison,
For a clear understanding/explanation.
