WRVS4400N v2 firmware - where is it?
Where do I find firmware updates for WRVS4400N v2?
I have just set one up with VPN to a WRVS4400N v1 (maybe v1.1). that works.
But the Wireless clients does not work very good.
Sometimes they cannot connect, other times they work fine.
I have no LAN-clients except for a printer with static IP.
I can see there have been problems with v1 and v1.1 when there is no LAN DHCP clients. Is it the same problem here?
I suppose there is a chance that a new firmware could help me.
My current firmware is: v1.00.09-etsi
wiktor.kaczynski Thu, 06/11/2009 - 11:22
Where's new firmware?
I buy this router I have problems.. WLAN disconnected.
petrkosec Sat, 07/11/2009 - 08:09
VPN don't work correctly. I have v2 and firmware 1.00.09. where is new firmware?
Te-Kai Liu Sat, 07/11/2009 - 16:40
  • Gold, 750 points or more
1.00.09 is the latest firmware for WRVS4400N V2. What kind of VPN issue did you encounter?
petrkosec Sat, 07/11/2009 - 17:20
I have Linksys QickVPN 1.2.11 and pem certificate on client.
When I connecting to VPN - Connecting - Activating Policy - Verifying Network - The remote gateway is not responding. Do you want to wait?
Te-Kai Liu Sat, 07/11/2009 - 18:52
When you saw the "Do you want to wait?" pop-up message, were you be able to access the resources in the remote LAN, e.g. web server or ftp server? The pop-up simply indicated that the QuickVPN client cannot ping the QuickVPN router's LAN IP, which is usually blocked by firewalls installed on the QuickVPN client. This is not a defect of the router.
jarharpe Tue, 07/14/2009 - 10:45
That is the latest greatest firmware out for v2 wrvs4400n
Megasly11 Tue, 08/18/2009 - 02:27
Where it is possible to download itself 1.00.09?
Steven DiStefano Thu, 09/10/2009 - 23:38
  • Blue, 1500 points or more
I just checked for someone and saw it available now.  Version 2.0.0.7 (WRVS4400Nv2-fw-2.0.0.7-K9.img) inside that ZIP as well as a version 40 IPS file....
snoylekim1 Fri, 09/11/2009 - 10:59
  Nice that's it's finally here.. are there release notes to describe what's been addressed, etc .. Saw one for the signature file, but all I se is the firmware image .. Readme would also be helpful to determine if this release requires complete factory reset, etc ...  Thanks
Related Content
