04-29-2009 02:21 AM - edited 03-06-2019 05:26 AM
Hi ,
g0/0 of 3845 router is connected to g3/47 of 3550 switch.
3845 config :
Int g0/0
speed 100
duplex full
int g0/0.11
encapsulation dot1q 11 native
ip address 10.10.10.2 255.255.255.0
standby 11 ip 10.10.10.1
int g0/0.12
encapsulation dot1q 12
ip address 20.20.20.2 255.255.255.0
standby 11 ip 20.20.20.1
4506 switch :
int g3/47
switchport mode trunk
switchport trunk native vlan 11
switchport trunk allowed vlan 11,12
int vlan 11
ip address 10.10.10.4 255.255.255.0
As soon as I connect Gig0/0 of 3845 router to Gig3/47 of 4506 switch, gig ports of both the deives are down and are not coming up.What could be the reason..
Satish
04-29-2009 02:31 AM
and if you configure speed on the 3845 to auto?
or if you configure both ends to speed 100(0)
04-29-2009 03:34 AM
Hi ,
I tried few combinations by chaning the speed and duplex settings...after that also ports are not coming up...
Satish
04-29-2009 03:39 AM
and you're using the correct cable?
04-29-2009 03:52 AM
yah am using machine crimped straight cable..
satish
04-29-2009 04:59 AM
IS the module you are trying to connect to actually up , do a show mod and make sure it passed diags and looks ok.
04-29-2009 04:10 PM
Hi Satish,
1. Try a different copper cable;
2. A stupid question: On the 4500, VLAN 11 is "no shut"?
3. Anything in the logs of both appliance to explain why the ports are down?
