caller quality on spa9000 and UK regional settings
Apr 29th, 2009
I have a strange situation in that during a call if the the 1st party is talking, and the 2nd party tries to talk at the same time (I know very bad mannered) - they cannot be heard. It seems that both parties cannot talk at the same time.. I understand this might be silence supression that is causing this ? But do not know where this setting might be (SPA9000 or each phone) and if this really is the culprit.
Also as I am based in the UK is there a definitive set of default values for the SPA9000 for regional / caller ID settings ?
Many thanks
Marc
Alberto Montilla Wed, 04/29/2009 - 05:45
Dear Marc;
I would need a bit more information about the environment where this is happening.
- Which phone models are involved?
- Are you using speakerphone? This is pretty common on speakerphone mode.
- Which firmware are you using?
- Could you please attach the configuration of one of these phones? To do this please follow the instructions below.
/docs/DOC-9933
With regards of the settings for UK, yes, there are the final settings available and attached. Just replace the existing UK file on the wizard (version 2.1).
regards;
Alberto
Alberto Montilla Mon, 05/04/2009 - 03:12
Dear Marc;
I've escalated this issue. I suspect this is normal operation in the SPA9X1 phone family, but will reconfirm with my colleagues. As soon as I get a response I'll let you know.
Regards;
Alberto
