ASA VPN Lan-toLan - Failover long distance - DR
Apr 29th, 2009
Hi all!
I wonder if a solution is possible for failover lan-to-lan with the secondary (failover) on another website (long distance), using a switch to the solution between the primary and secondary.
Attachment topology as an example.
I Appreciate any help.
Overall Rating: 5 (1 ratings)
jrmalmeida Wed, 04/29/2009 - 05:56
Hi Andrew!
Yes, the company is an IP address and DR is other IP.
The 2 sites are serviced by the same ISP.
Thank you.
