QoS problems on 877W
Apr 29th, 2009
Can QoS be configured on the 877W router using the Fastethernet interface not the ATM0?
I have configured QoS on an 877W router but it's not effective, please advise as to where is the problem.
877W
ip access-list extended Gr1
permit ip any host 192.2.1.2
ip access-list extended Gr2
permit ip any host 192.2.1.3
ip access-list extended Gr3
permit ip any host 192.2.1.4
class-map match-any CusBusBulk
match access-group name Gr3
class-map match-any CusSysMgt
match access-group name Gr2
class-map match-any CusIntBusData
match access-group name Gr1
interface FastEthernet0
bandwidth 2000
service-policy output QoS
interface FastEthernet1
switchport access vlan 2
interface Vlan1
description Connection to Router 3825
bandwidth 2000
ip address 192.1.1.1 255.255.255.252
ip virtual-reassembly
interface Vlan2
description Home LAN
ip address 192.4.1.1 255.255.255.0
policy-map QoS
class CusIntBusData
bandwidth 64
police 64000 1000 1000 conform-action transmit exceed-action drop violate-action drop
class class-default
fair-queue
John Blakley Wed, 04/29/2009 - 05:42
  • Purple, 4500 points or more
If you're trying to control upload speed, this should work fine, but if you're trying to control download speed, you're going to have a hard time doing it. I'm assuming that you're running nat somewhere on this router (although I don't see it in the post). NAT happens before QoS methods take effect, and your returning traffic will reference your public ip address. It's hard to control your returning traffic.
HTH,
John
mailaglady2 Wed, 04/29/2009 - 06:37
No I am not running NAT, this is just a lab scenario. Yes I am trying to control the upload traffic, my problem here is my policing is not working so that automatically tells me my QoS is not effective. I have noticed in most of the documents that I read they use Fastethernet4 as their wan link and seemingly QoS works fine. But all the 877 that I have seen do not have F4, they only have F0 up to F3.
John Blakley Wed, 04/29/2009 - 06:49
Sorry....disregard my last post. (I thought I was answering someone else.)
If you're wanting to control traffic only on F0 (which your config suggests), you would need to have a device connected directly to F0. If you don't have anything connected directly to F0, then you can control traffic by putting your service policy on your vlan1 (if F0 is a member of that vlan).
Can you post "sh policy-map int fa0"?
HTH,
John
mailaglady2 Wed, 04/29/2009 - 10:39
Yes the other router is connected directly on the f0, they connected back to back.
My Vlan interface don't want to accept my service-policy, here is the output whenever I try to apply the service policy on the vlan interface
Router_877W(config-if)#service-policy output QoS
Configuration failed!
Router_877W#sh policy-map int f0
FastEthernet0
Service-policy output: QoS
Class-map: CusIntBusData (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: access-group name Gr1
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 265
Bandwidth 64 (kbps)Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
(depth/total drops/no-buffer drops) 0/0/0
police:
cir 64000 bps, bc 1000 bytes, be 1000 bytes
conformed 0 packets, 0 bytes; actions:
transmit
exceeded 0 packets, 0 bytes; actions:
drop
violated 0 packets, 0 bytes; actions:
drop
conformed 0 bps, exceed 0 bps, violate 0 bps
Class-map: class-default (match-any)
18958 packets, 1318632 bytes
Match: any
Queueing
Flow Based Fair Queueing
Maximum Number of Hashed Queues 256
(total queued/total drops/no-buffer drops) 0/0/0
John Blakley Wed, 04/29/2009 - 11:12
Okay, since a device is connected directly to the port, try changing the direction of your service policy to input. See if that helps.
John
