Remote Site and Site-to-Site VPN Combination
Apr 29th, 2009
I am trying to design a VPN solution (Network Diagram attached). Requirement is to allow remote site VPN user to get into offshore network and then that user should access onsite application through existing site-to-site tunnel between onsite and offshore network.
Remote user can successfully get into offshore network but he is not able to access onsite application through existing site-to-site VPN tunnel. I checked the PIX firewall logs and it showing me error with syslog ID 302014(Flow is a loopback).
Has anybody worked on such design?
Akshay
akshay.dm Wed, 04/29/2009 - 06:30
Thanks for your quick response.
IP pool which I used for remote VPN users is a part of the internal subnet used in site-to-site encryption domain. Hence first two points mentioned by you are covered. I did try 'same-security-traffic permit intra-interface' but that didn't make any difference. I am still getting the same error.
