Notification for changes made in the devices
Apr 29th, 2009
Want to configure ,whenever their will be any changes in configuration of the devices get notification on the server as well as on email.
How can be configure the same and need detailed description of the same.
Plse let me know the solution
Sven Hruza Wed, 04/29/2009 - 07:08
I suppose that you have LMS installed on your server :)
You can configure a syslog server on your devices. This should be your LMS server.
You should configure the severity level for the syslog messages you want to send.
logging trap notifications ! the severity level
logging source-interface Vlan1 ! your mgmt-interface of the device
logging ! the logging server
Then you have to activate the traps on the device.
If you want to enable all traps, use
snmp-server enable traps
or if you only want to get config-messages you should use
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
Finally you can define an email-notification under
RME -> Tools -> Syslog -> Automated Actions
Select the sysylog messages " %SYS-5-CONFIG_I " and generate an email out of it.
vaibhav-g Wed, 04/29/2009 - 22:40
i have se that..getting E-mail notification is not clear what exactly changes made on the device...
It just alerting ...can i get the details what changes has been done....
Sven Hruza Wed, 04/29/2009 - 23:26
I think that is not possible if you want it automatically.
You can look for differences between the old and the new config by using the config archive.
But I think that there is no way to send this differences by mail.
