Historical Reports login issue
Apr 29th, 2009
I've assigned Reporting privelleges to some users within UCCX version 7.0.
I installed ths Historical Reports plugin. When I launch Historical Reports and enter the username and password I get an error message:
Failed to login to database. Ask your administrator to check the database user id and password that is dynamically obtained from the Unified CCX server'
For the username I enter the CCM userid.
Does anybody know how this problem can be resolved?
Overall Rating: 5 (2 ratings)
chadlincoln Wed, 04/29/2009 - 09:05
  • Bronze, 100 points or more
You posted this twice so I'm not sure which one you'll check, but here was my response in the other thread:
Log in to IPCC.
Click Tools, User management
Click the user who is trying to log in.
Confirm that their selected capabilities contains Reporting.
Please rate if this helped. Thanks.
siggiv Tue, 04/13/2010 - 00:54
I know this is an old post but I had the same problem and I the problem was I had changed the SQL Authentication to Mixed mode because of Wallboard testing. Change it to Windows only and it works.
Now I just have to find out what to do with my wallboard.
Aaron Harrison Tue, 04/13/2010 - 00:59
  • Community Spotlight Award,
    Member's Choice, May 2015
Mixed mode authentication is actually supported in 7.0 SR5; if you upgrade to that, check the release notes for details.
Aaron
Please rate helpful posts...
siggiv Tue, 04/13/2010 - 01:05
Thank you but I have 7.0(1)SR05_Build504 and I tried changing the hrcConfig file to "AUTH=1" but no luck.
Have your tried this your self ?
Aaron Harrison Tue, 04/13/2010 - 01:49
Yes, tried this in the lab, and have one customer running this quite happily.
The confusing bit is the hrcconfig.ini, as you suggest. There is a section like this:
DRIVER=SQL Server
SERVER=192.168.0.171\CRSSQL
DATABASE=db_cra
AUTH=1
NETWORK=dbmssocn
PORT=4433
UID=db_cra
;Use this key to specify alternative values to connect to Cisco CRA database instead of using the default values
DRIVER=
SERVER=
DATABASE=
PORT=
;AUTH specifies the authentication mode to use while connecting to the database.
;Use one of the following values:
;1 - Windows NT Authentication
;2 - Mixed Mode Authentication
AUTH=1
The release notes point out you should set AUTH=1. The first time I did this, I made the mistake of reading the descriptions in the ini file, and set it to 2 - no good.
The first section seems to update dynamically; you don't edit that.
It's the second AUTH= parameter that you need to set.
Then it worked fine for me...
Aaron
