CUPS 6.0.4.1000-4 - Unable to view Calendar Information
Apr 29th, 2009
I have a CUP Server integrated with a CUCM 6.1(2). Exchange backend is 2003 with SP2. Everything else works beautifully (unity integration, MPE integration, etc). Troubleshooter shows that the ssl cert for exchange is installed and gets the green check. CUPC client is the latest 7 version. Looking over the debugs it seems like everything is ok, has anyone run into this before?
04/29/2009 09:45:44.869 EPE|system.pe.pa.owa.backend 76698 DEBUG Calendar.notify Exchange server ADD or UPDATE
|<CLID::StandAloneCluster><NID::172.30.2.62><LVL::Detailed><MASK::0800>
04/29/2009 09:45:44.869 EPE|system.pe.pa.owa.backend 76698 DEBUG HostName: calendar.ad.ebc
04/29/2009 09:45:44.869 EPE|system.pe.pa.owa.backend 76698 DEBUG Server: owa.ad.ebc:443
04/29/2009 09:45:44.869 EPE|system.pe.pa.owa.backend 76698 DEBUG AccountName: cup@ad.ebc
04/29/2009 09:45:44.869 EPE|system.pe.pa.owa.backend 76698 DEBUG SubjectCN: owa.ad.ebc
04/29/2009 09:45:44.869 EPE|system.pe.pa.owa.backend 76698 DEBUG -->ExchangeSession::certificateExist: /usr/local/sip/.security/pe/trust-certs
04/29/2009 09:45:44.871 EPE|system.pe.pa.owa.backend 76698 DEBUG <--ExchangeSession::certificateExist: 1
04/29/2009 09:45:44.871 EPE|system.pe.pa.owa.backend 76698 DEBUG <--BackendGatewayObserver.notify<record>
04/29/2009 09:45:44.871 EPE|system.pe.pa.owa.backend 76698 DEBUG -->BackendGatewayObserver.notify<record>
04/29/2009 09:45:44.871 EPE|system.pe.pa.owa.backend 76698 DEBUG <--BackendGatewayObserver.notify<recordsholder>
04/29/2009 09:45:44.871 EPE|system.pe.pa.owa.backend 76698 DEBUG attach to the cache
04/29/2009 09:45:44.871 EPE|system.pe.storage 76698 DEBUG StorageSubject 239727768::attach
04/29/2009 09:45:44.871 EPE|system.pe.pa.owa.backend 76698 DEBUG <--BackendGatewayObserver::init
04/29/2009 09:45:44.875 EPE|system.pe.pa.owa.backend 76698 DEBUG <--Calendar::init
04/29/2009 09:45:44.875 EPE|system.pe.pa.owa.backend 76698 DEBUG <--OwaBackendAdapter.init
04/29/2009 09:45:44.875 EPE|system.pe.pa.backend 76698 DEBUG Checking status
04/29/2009 09:45:44.875 EPE|system.pe.pa.backend 76698 DEBUG status success
Tommer Catlin Wed, 04/29/2009 - 08:29
  • Green, 3000 points or more
On the Exchange server, in the Event Viewer, do you see the account used for CUPS logging into the Exchange server (with the CUPS IP address) and requesting the information? If you do, then the SSL is working. If you do not, then the SSL is broken or not working.
jcarlyle Wed, 04/29/2009 - 08:39
not sure what you mean by seeing it request the information. I can see the cup account make a successful logon in the security logs, but no status is pushed to the clients. I also confirmed i can log into OWA with the cup account and view user's calendars.
Tommer Catlin Wed, 04/29/2009 - 08:55
Ok, that is good then you see in the security logs on Exchange the CUPS logging in. Is this a new setup or did it just stop working?
jcarlyle Wed, 04/29/2009 - 10:06
New install, everything here is new actually, it's technically a lab environment.
Tommer Catlin Wed, 04/29/2009 - 10:24
couple things to check....
6.05 is a better version to use. ( i know, upgrade to fix, but when dealing with CUPS, upgrade is better.)
Restart the CUPS server (or services)
For the user you have configured, ensure that cal is enabled. I cant remember on 6.x of cups if it has the presence viewer like in 7.x of cups.
Sometimes, just simple reboots and the thing starts working.
Michael from TAC may see this post also and comment. He's the wizard on CUPS and can probably tell you from the log file whats going on.
htluo Wed, 04/29/2009 - 20:09
  • Red, 2250 points or more
Could you do the following?
1) Make sure presence engine trace level is set to debug.
2) On CUPC > File > Preference > Status, see if "show me as in a meeting" was checked. If it was checked, toggle it off and back on. If it was not checked, check it.
3) Restart presence engine. Wait for 2 minutes after it comes back up.
4) Log into CUPC.
5) Collect Presence Engine logs. Make sure it covers the time you restart the engine and the time you log into CUPC.
6) Upload logs here.
Thanks!
Michael
http://htluo.blogspot.com
