rate limit per user traffic with WLC
Apr 29th, 2009
Hello ,
I would like to limit the user bandwidth with WLC. I would like to sell the internet service to the houses which are provided to employees. For this reason i am traying to limit the speed for the per user.
In this address ; http://www.cisco.com/en/US/docs/wireless/controller/5.2/configuration/guide/c52ccfg.html#wpxref21838
Using the CLI to Configure QoS Profiles
To define the average data rate in Kbps for TCP traffic per user, enter this command:
config qos average-data-rate {bronze | silver | gold | platinum} rate
I see this command option. What is this for , is this option helps me ?
Regards...
carenas123 Thu, 05/07/2009 - 11:12
To define the average data rate in Kbps for TCP traffic per user, use the config qos average-data-rate command.
hasmurizal Mon, 05/11/2009 - 19:12
hi
those config are for QoS profile, which i think is not the bandwidth limit for the user. perhaps you might consider another appliance which can do traffic-shapping or you can surf on the net for router traffic shapping (try limitting via ip address bw allocation)
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
