PFC console login
Apr 29th, 2009
I am trying to connect a console to the active sup 2 on a cat 6500 and it takes me into the msfc directly. why is that ? Is it because I previouse logged in using session mod..... command. How do i exit and back to the L2.
Thanks in advance,
cheers
sundar
hadbou Tue, 05/05/2009 - 07:39
  • Bronze, 100 points or more
You can enter the switch console command to access the MSFC CLI from the supervisor engine CLI directly connected to the console port. To exit from the MSFC CLI and return to the supervisor engine CLI, enter ^C^C^C at the Router> prompt.
